Wisconsin | I can't help much other than it's a circulation issue. We had to replace the hoses on the 2-155 we have and the new hoses were a pain to prime the air out of. I know I thought there should be some sort of pressure to pump the fluid through the hoses but in fact it work's more on hot rises and cold lower's to create flow. We put hoses on filled system and left one of the hose clamp's in back of the cab loose and after really using it good it started to leak and system was primed and we tightened the clamp. | |
