| I had no troubles doing it with EZ steer 500 rtk with mx tractor and a 12/23 case ih planter. Harvested with 8010 and a 8 row head ez steer rtk.
Fried of mine with a 16/31 case planter and 7010 combine had no troubles either. I planted with a heading and did not even use the same ab line. Just lined up on the corn and went. I do know of guys having trouble with a 24 row kinze following with ez steer rtk and it is off some side to side a bit. It will always get him on the right row. Just seems the the row has a little wiggle in it. It might be what planter you use the 1200 pt bulk fill is not a light planter. These were in fairly level fields. I could see trouble on a big hill side.
