Posted 11/10/2009 08:12 (#919008 - in reply to #918015) Subject: RE: Big shave
NW MN
You know, I was wondering if I could hook my JD 930 and 925 heads to the IH cable system. I used the system with the cable on my 820 heads and that worked wonderfully. If I could get the JD heads to work with the cable system, that would be perfect and simple to boot. Are you using this set-up currently? Any info would be greatly appreciated. Thanks.
