Posted 11/9/2009 09:08 (#918022 - in reply to #917661) Subject: RE: problems with cab lights on Case IH 9170
NE South Dakota
If I remember there are two or more wires to the 30 amp breaker that is over loaded.....there is room to put another 30 amp breaker in the line up,you will now have half the load on each breaker....I made this change on my 9170 last spring.....problem solved.
