Posted 11/8/2009 23:21 (#917735 - in reply to #917625) Subject: Re: JD 9600 loosing power
Anamoose, ND
OK if you have good fuel flow from the bottom of the tank I would check the small 12v pump that sends fuel up to the filters. Take the hose off of the discharge side and turn the key on. You should have good fuel flow. These pumps are know for going bad. I have to pick one up for our JD payloader in the morning. By the way NAPA is a lot cheaper than JD.
