Posted 11/8/2009 20:02 (#917307 - in reply to #917268) Subject: Re: Why won't my N-14 Cummins rev higher than 1500 rpm
Went thru this problem last year. If the truck has thrown a code such as loss of transmission output speed sensor, the computer goes into a limp mode that limits rpm to 1500. The sweet deal is it takes someone with a code reader to reset the computer as simply fixing the problem with say a new sensor or wire repair will not be enough. Cummins has made some enemies over the years with their electronics BS. Good luck
