West Central Iowa | Looking at getting a disc ripper. Needing something that will do a good job of burying trash, yet leave it level enought to apply chemical in the spring, one pass with a field finisher and plant it. Currently using a disc chisel and have to hit it again with a disc to level it off before spraying. Looking at JD 510, Landoll Weatherproffer II and Sunflower 4410. Pros and cons of each? Also 5 or 7 shank? Will be pulling with a 300 hp 4x4 on level ground.
Thanks! | |
