| Thank you to all that replied on my questions ,earlier post , on the combine acting up and giving the codes. I replaced the transfer pump ,thought i had it solved untill tonight,same story. hi idle then dies. After reading the replies i open the connection under the black box and found corrision. Cleaned it up and it ran great for four hours tonight. Again thank you for the suggestion to look for | |
