Posted 11/5/2009 21:37 (#914793 - in reply to #914649) Subject: Re: R62 ROCK DOOR
N.E. Iowa
there is a door adjustment inside the rotor compartment I believe they are 3/8 bolts and maybe 5 or 6 of them also the two 1/2 inch bolts that are welded to the plate are for rock door adjustment. When the door is shut you shouldn't be able to move it up and down if you can than you need to make a adjustment in the rotor compartment
