Golden, IL | Cornstalk has it right.They also don't pack the ground near as bad as is evident when you go to plow .It don't pull much harder where you loaded all the trucks than anywhere else in the field.It also is like having another combine in the field cause you can unload on the go anywhere you want.We've got a 95e on 1050 kinze with steel boogies. Have to clean the stalks out of the tractor out once in a while but not the cart. | |
