Posted 10/25/2009 22:25 (#900159 - in reply to #899775) Subject: Re: Are there any advantages of a 252/262 over an EZ Guide 500?
Cedar Rapids, Iowa
If you're going to leave the 500 in there anyway, just use it to do the steering. If you do this, you can still connect the Pro600 to the EzGuide 500 to get NMEA position data for stuff like section control or logging on the Pro600.
If you were to get a 252/262 and reflash your NavII with CNH firmware, then you could use the Pro600 to steer the tractor.
