Central Nebraska | If you're looking at the InSight but are using your 500 for guidance, you might consider the InSight's baby sister, the Edge. It doesn't have nearly the amount of features the InSight has but if all you really need is a yield monitor and mapping, it would save you about 2k. You can output the GPS from the 500 (actually, from your NavII if you are using one) to the InSight or Edge really inexpensively, with just a serial cable and a null modem cable. | |
