| 09' machines are supposed to be on Can Bus sensors now. So Insight can use mass flow sensor. No matter what machine the side mount unit and moisture sensor can be used with Insight with proper cableing. With your 2388 and 2588 the flow sensor is the older style sensor and will need to be removed and replaced with can bus flow sensor.
You will however have to run separate wireing and mount modules for Insight. | |
