Posted 10/22/2009 22:58 (#895627 - in reply to #895063) Subject: RE: John Deere hydraulic drive on Kinze planter
Clatonia, NE
I don't think the mechanics will be a problem. You'll probably need to run the Insight on this planter in order to adapt to the Kinze Mux bus and run the Deere drive at the same time. I can put together what you'll need and get you a quote if you want to know what it would cost. You could make the system complete with surestop clutches.
