Posted 10/20/2009 11:15 (#892127 - in reply to #892033) Subject: RE: Moisture Calibration 9670
I wouldnt touch it, the calibration does nothing for the moisture part of it, just the little electric actuator that run in the moisture tester. You can enter a manual adjustment factor to compensate in difference between you combine test and the tester you are using for a benchmark.
