Posted 10/14/2009 20:14 (#884730 - in reply to #884583) Subject: Re: GPS interfears with VHF Radio
Dashwood, ON
You may have seen my post in the equipment side, but the ATC is not likely your primary concern but rather the wiring for the radio. Best way to do it is ground directly to the battery and use switched power to trip a relay with clean battery power on the radio side of things.
