Posted 10/14/2009 10:37 (#884143 - in reply to #883781) Subject: Re: Trimble FMX - Glonass only on RTK?
GLONASS only helps your accuracy when it is calculated into the correction. So until WAAS and Omnistar add the GLONASS sats into their correction calculation you will recieve no benifit from them. There has been talk about Omnistar coming up with a GLONASS solution, but until then RTK is the only way to take advantage of GLONASS.
