Ladoga, IN, United States, North America, Earth | The Pro-600 will run the guidance on a 275. It will have a 262 receiver, that is a Trimble receiver. It also has a NavII like a Trimble system, however this is where the differences start.
The NavII for Accuguide has CNH firmware on it, which is what allows the Pro-600 to control it. If you wanted to go between a CNH Accuguide to a Trimble autopilot, you can use the NavII and the 262 but you have to have the firmware flashed in the NavII back to Trimble software.
For a CNH Accuguide, you can get a Trimble Autopilot wiring harness, approx $300 and run your Trimble display on your CNH tractor. |
