Spain | You donĀ“t need NavII, you need the VM415 connected to the back of the tractor using the cable assembly (PN 57765 and PN 0793-1030).
You need calibrate the FLII system before you can start working:
-> Turn the tractor ignition switch to the off position.
-> Start the tractor while simultaneously holding in the TRACTOR and HITCH switches. continue to hold the two switches after the engine starts until the DIAGNOSTIC screen appears on the tractor display. ( 2 or 3 seconds), rotate the selector Knob until SCU.001T appears and press the LEFT ARROW switch in order to accept SCU.001-T.
-> Rotate the selector knob until CAL:051 is displayed and press the LEFT ARROW switch to accept.
->Rotate the selector knob to highlight the center icon (right pointing arrow) and press the LEFT ARROW switch to accept.
-> A 30 second time starts, then put the tractor hydraulic system into Active Control (AC) moving the JD hid. paddle switch into its downward detent position and then releasing it.
-> Press the start calibration switch on the FMD/FMX ( with RTK fixed,etc) and the system will start moving for 8/10 minutes.
->At the completion of calibration, turn the tractor ignition switch off.
( faults on the tractor must be cleared before the calibration process)
(When NOT in diagnostic mode, to see the hydraulics working,the tractor must be moving faster than 0.5 Km/h) | |
