Edwall, Wa | You have the new cabling which just came out.....Do you have a 67087 you could try in place of the new cabling? You would also need a 62974 which plugs into the EZ-Steer controller and you would also have to send power to the EZ-Steer controler through the 62974 as well as remove the red and white wire in deutch connector from the 67087 where it connects to 62974 so power doesn't feed back into the FMX. That is the only way I have tried EZ-Steer with the FMX I have not used the new cabling yet. Have you talked to tech support at all? | |
