Mmaxed - 9/22/2009 00:19
You have it closer than I would have expected possible. If the 500 is flashing up a flow error go into the application menus and turn off application control. This may let the mapping work.
Yeah so close but still miles away!! No error messages come up on the screen. You can't turn off rate control unless you have EZ-Boom selected as your controller. The only options you get when choosing a Raven is what port the VRA will use.
Nmea is outputting on the AUX port to the AS7500.
AS7500 is sending a raven data stream to the COM port on the 500. |
