Search Forums | Classifieds (28) | Skins | Language
Massey Autoguide/ Agleader. No can communication
c_mayer
Posted 5/9/2025 16:58 (#11219317 - in reply to #11219240)
Subject: RE: Massey Autoguide/ Agleader. No can communication
Jeffersonville, OH
iafarmerboy220 - 5/9/2025 15:13
Interesting. It’s the soft switches. What messes me up is when I press the button I get can communication for a half second and then it shuts off
Assuming it's worked on this tractor before...
If your buttons are lit up, then I would suspect a CAN issue with the valve...possible a bad PVED head...ie, the elctronic part of the valve.
Try your auto 4wd, and see if it turns on and off as you turn the steering wheel...if that works, then your wheel angle sensor is working.
Also, try the speed steer function...if it works, then the valve is working...but I guess doesn't necessarily rule out a CAN issue with the valve.
Where is the Ag Leader tied in, to the diagnostic plugs, or behind the pillar near the ignition switch into connector X282?
Chris
