JD 2630 not seeing fmx 1000 tractor speed
GcDm2010
Posted 5/6/2025 18:46 (#11216048 - in reply to #11216031)
Subject: RE: JD 2630 not seeing fmx 1000 tractor speed
SOIL
On the Deere, Go to Menu > Performance Monitor > Settings. Check or uncheck the Use Radar As Speed Source box.
FMX: Your VTG needs to be ON.
Also try turning your FMX Baud Rate up to 38400. 19.2 might be too slow to hand all the needed data over.
One more thing, I may be wrong, but your Lat/Lon precision should probably be more than 1? I think that means decimal location, in which it should be at least 6.
Edited by GcDm2010 5/6/2025 18:50
