Posted 9/13/2009 23:05 (#845959 - in reply to #844773) Subject: Re: EZ 500 / EZ steer on uneven ground ?
North west MN
I think you might have the terrain comp box mounted in a different direction than you have entered in the calibration go through the terrain comp calibration and make sure you have the cables facing the way you tell the calibration wizard. I have seen this many times and it is a easy mistake to make and fix.
