| At this point I think the upgrade code, which you are right @ 2k will get you the code and an AgGPS25 antenna. Replaces the Zephyr. Even if you buy the zephyr, there is no break on the price of the EZG500 upgrade. You would definitely be better off with the new antenna and the full warranty it carries. You can then pipe the GPS out from the 500 to the PRO600. That way you only have one unit on the tractor like you wanted. | |
