Slicker than a Yes album. | Things are different across the country. Boss usually eyeballs runs, used the grade rod if there's a question. We don't map until the tile is in the ground, that way there is no question if there is tile there. If you're laying it out, maybe something happens that the line shifts one way or the other. I don't believe the brown box showed distance traveled. Use to use JDOffice, but now I know how to do it with the line flag like you. Next fields will be done that way. Wish I could import those lines from JDO into Apex. |
