Western Iowa | I use EZ500/ezsteer with omnistar xp and had good luck. It was mostly within 1-2" on corn guess rows. It is more accurate than I can plant. Convergence time is a killer though.....about 15 min if you loose your signal or start up in the morning. Most of the time it is tolerable...unless you are around trees then use your marker. Once it is locked on, you are good all day or until you shut it off. (I leave mine on all night) Hope this helps.
Here is a video of it in action.
http://www.youtube.com/watch?v=fbK7Jo0HSCg
Edited by iafarmerken 9/9/2009 21:15
