| If your 23 is like a 21series i mounted my ezguide 500 on the A post towards the right side door just kinda inbehind the A post plastic
case Ih welded a angle brace and it already has two holes drilled i tapped those holes plus put nuts not much room to work and mounted a flat stock 4"x 5" so it angles toward the seat then i bolted a 2x3 piece of angle iron to that with my ram mount on the face that angle iron with ram mount does double duty in my spray tractor
have it out of combine atm but i knew i should have taken pictures when i had it in there lol
it covers line of sight to grain lost dials a bit when all installed but thats ok
Edited by Gambler 9/9/2009 10:13
