Ladoga, IN, United States, North America, Earth | It is not hard at all to wire up an Ez-boom into electric clutches. You can either run new wires back to the clutches, or find them in the wire harness running to the switch box. All you will need to do then is T into the wire going to each clutch and you'll be set.
Should be noted that you need to make sure the clutches are in good working order and aren't pulling more than 16 amps. That is all the Ez-Boom can handle. You could wire up a simple relay system to take the power draw away from the Ez-boom. |
