Search Forums | Classifieds (101) | Skins | Language
Incommand NTRIP issues
aNullValue
Posted 10/28/2024 21:57 (#10942442 - in reply to #10942353)
Subject: RE: Incommand NTRIP issues
Fairfield County, Ohio, USA
caseihfarmer - 10/28/2024 22:18
seems like you have kind of narrowed it down. i have recently been having similar issues and could not figure it out. my situation was almost identical to yours with different hardware, mine is an incommand 1200, 7500 and legacy steer command. my problem seems to me to be that the usb port that the wifi adapter is plugged into is getting worn out despite being secured by the screw properly. this particular display was bought the first year they came out. i can take the adaptor and wiggle it and replicate the issue. if aginiti is staying connected though for you this may not be your issue though i did notice that agfiniti took longer to show up not working than the connection to digifarm did. i was fighting it pretty hard and narrowed my issue down to that.
I've had the same problem you describe, though not since spring. I unscrewed the wifi adapter, unplugged it, plugged it back in, then screwed it back in, and it hasn't caused me any problems since. That InCommand is only... 2 years old... I think.
