 East Central Indiana | Yes, on flat ground autopath is working well for corn, especially since I have a shift track rocker switch on the hydro. Hill fields with lots of waterways still benefit when rowsense is turned on. As the combine rolls side to side, rowsense works better than autopath alone. One of my planter rows might be off an inch or two, because the rowsense offset needs adjusted each time I turn around. 16r 1775NT EE, 8r corn head.
edit: Autopath tried to make a 90* turn while I was cruising down the row a couple days ago. It saw some endrows nearby and wanted to harvest them instead of the path I was on. I think if rowsense had been activated, it would not have done that. Knocked over 10' of corn before i got stopped.
Edited by deereboy8400 9/23/2024 17:07
