| I don't know any specific numbers for your machine, but maybe can still help. If it works ok at a specific MPH, and not another, I will sometimes run another calibration wizard and run at the MPH that is not working (we do it a lot in sprayers). I know that it is only a couple MPH different, but it is really 50% slower - and that is probably where the issue lies. When you run the wizard, you don't have to do a roll cal again if it driving correctly at another speed. This way you can watch the screen and see how your changes are affecting the steering in real time. Save your original configuration before you do this to insure nothing gets totally messed up. You will probably need to change the angle per turn a couple of degrees to settle it down.
Hope this will help | |
