| Having issues with the "hold on min" check mark with the Falcon VT.
Nozzle pressure is set to 30 PSI and Max is 150 PSI when the "hold on min" is check that system will hold at 10 PSI not 30. Would seem like something is out of calibration, any suggestions on what to look for would be welcomed.
System has a rinex boom control added. Which seems to work fine, except when boom valves are turned off pressure increases to about 120 PSI. When the boom valves are opened pressure drops to zero and the nozzles dribble, while the flow rate slowly increases. It seems to me that the control valve is being turned off by either zero flow or too high of a pressure. Any idea as to how this is set?
Thanks | |
