NE Iowa | I have a terragator with a Viper 4+ that I'm switching the flow meter from the big krone flow meter to a Raven standard 3" flow meter with an impeller in it. The 3" flow meter I have has a tag on it that says 5 volts only, the cable coming from the controller has 12 volts on the black power wire & 5 volts on the signal wire. Do I need to reduce the 12 volt wire down to 5 volts also or is the tag just referring to the signal wire can't have more than 5 volts?? TIA
(PXL_20240724_203813102 (full).jpg)
(PXL_20240724_203802361 (full).jpg)
Attachments ----------------
PXL_20240724_203813102 (full).jpg (131KB - 224 downloads)
PXL_20240724_203802361 (full).jpg (147KB - 215 downloads)
