Posted 8/27/2009 16:23 (#826662 - in reply to #826337) Subject: Re: Some more header height sensor ?
Kentucky
all the pf is looking for is signal so if you make a straight through connector and t off the signal to the al harness you will be fine - be careful not to tap into the wrong wire
