Posted 8/27/2009 23:43 (#827289 - in reply to #826124) Subject: Re: Mounting a Raven 440 in a Versy 876
I am totally assuming that the 876 is similar to a 946. If thats the case I run my cables on the floor out the back of the cab into the compartment with the batteries, from there I drilled a hole in the door of the battery compartment, put a rubber grommet on it or it gets hard on your cables. The 440 and rest of gps stuff are mounted to a rail I made in the cab. I'll try to get some pics of the rail.
