North Central Iowa | A Trimble ez boom should work to replace the tee jet controller. Google the ez boom cabling guide, seems they have cables to connect directly to the Teejet flow meter and control valves. Not as sure about a plug and play ready connection to the valves. I’ve used an ez boom on my last 2 pull type sprayers and it worked pretty well. Used an ez steer with it as well. My earlier sprayer had a teejet 744?? controller that I modified the cabling to work with the ez boom. | |
