roaming | a couple of thoughts
1. When you start up the display, the display reads through all the data on the card. The more data on the card, the longer it takes to read. So if you're having slow performance at start up, remove some data (old GPS data) from the card.
2. Make sure you're not trying to put all your data into a single Field. Storing lots of data (from geographically different regions) in one Field can cause performance issues.
3. Exactly what software names/versions are installed in the display? Get rid of anything you're not using. | |
