Posted 3/12/2024 10:45 (#10662416 - in reply to #10655039) Subject: RE: SprayMate II to Fieldview
Quebec, Canada
For the in-furrow application with the planter, do you have a compatible planting rate controller (other than a 20/20)? If the fieldview drive can read planting rates then you can set the application rate controller to “incompatible rate controller”, tell the cab app what rate you are applying, and it will map a fixed rate fertilizer application whenever it sees seed being planted.
