Posted 8/20/2009 20:46 (#818428 - in reply to #815904) Subject: Re: FMX running on EZ-Steer
Sunnyvale, CA
check the GPS status screen and see if the SV signal strengths are up to what you have seen before. if you are in the clear, the SNRs should be in the mid 40's. if not might be antenna or something in the receiver, or even a lossy cable. could be some interfering source, like a neighbor with an old 150-160 MHz radio several miles away jamming the SV signals.
