Pro 1200 with case antenna
mx270a
Posted 5/29/2023 12:14 (#10248139 - in reply to #10246971)
Subject: RE: Pro 1200 with case antenna
Cedar Rapids, Iowa
Is it the Vector Pro receiver on an AFS connect tractor? Are you running AFS 1, 2, or 3? These tractors keep the receiver powered on for 24+ hours after you shut the key off to keep the correction signal converged. Maybe it just needs a good reboot to get things going again, which doesn't happen when you turn off the tractor. Try unplugging the receiver for 5 seconds so it truly powers off.
