Search Forums | Classifieds (86) | Skins | Language
Gen 4 4600 and Raven Liquid Controller will not variable rate
Schuerman Farms
Posted 5/25/2023 21:20 (#10243696 - in reply to #10243617)
Subject: RE: Gen 4 4640 and Raven Liquid Controller will not variable rate
WC MN & Valley of the Sun, AZ
Did prescription liquid fertilizer on the planter for the first time this year and took the first field to learn the hard way poking around in menus while the planter autosteered down the field.  It's actually quite simple if this is your same issue -- Change the rate from XX gal/ac in the rate box to "Map-Based"
(2023-05-25 21-19-45_DT.pptx - PowerPoint (full).png)
Attachments 2023-05-25 21-19-45_DT.pptx - PowerPoint (full).png (103KB - 121 downloads)
