Coldwater, Michigan | That would depend to an extent on the % of MN in the product. Generally an EDTA Mn is recommended at 1 quart to the acre in normal conditions, if it was a severe deficiency up to 2 quarts could be appropriate. I usually would also recommend up to 1 gallon of 28% UAN in the mixture if you are going to be breaking it up sufficiently. If not, you might want to cut back to 1 quart of 28%/acre.
