Search Forums | Classifieds (176) | Skins | Language
Whats the best way to get AB lines from one pro 700 to another?
torn
Posted 5/17/2023 06:36 (#10232222 - in reply to #10232174)
Subject: RE: Whats the best way to get AB lines from one pro 700 to another?
roaming
midwest - 5/17/2023 04:10
From my memory of transferring stuff with a USB.
If you’re going to transfer lines and farm/field data using a USB from tractor to tractor.
I would delete the old guidance lines and farm/field data from any tractor you’re going to transfer data into using that memory stick before you do anything.
Otherwise, when you put that stick back in your Pro700 of your first tractor, you’re going to end up with a bunch of lines and junk from every tractor that stick has been in.
And if you don’t clean up the memory sticks in tractors you are transferring lines to, when you put that old memory stick back in the tractor and power it up, all that old data is going back into the Pro700.
Good advice.
