just a tish NE of central ND | OK < Ill try to clarify bolting washers/weights under the rub bars. I should have said I would consider bolting them behind the rub bar brackets so that it doesnt interfere with the rub bar. That would consist of not removing the bolt, but just the nut and adding weight between the nut and the bracket.
My shops around here suggest trial and error, but there surely is somethign better. A few shops tell me they put the rotor on a stand with 2 bearings and jsut guess balance them and it is good enough. I sure dont like unessessary vibration on any machine.It will wreck stuff in short order.
Edited by School Of Hard Knock 7/25/2009 20:49
