Search Forums | Classifieds (176) | Skins | Language
Pro 700 task controller
raider2b
Posted 5/6/2023 08:17 (#10217916 - in reply to #10217786)
Subject: RE: Pro 700 task controller
North Dakota
Try to get your 700 updated to task control version 31.36 at the minimum. Current version is 35.2. After 31.26 task control was changed to operate better and is easier to use. When you update the 700 you will also need to update the NAV and the receiver.
Some early versions of task (prior to 31) had various issues with how it recorded coverage. Some early versions of 31 had problems with recording too much data and would overload the 700 slowing it down. Anything after 32 seems to be OK.
