Search Forums | Classifieds (76) | Skins | Language
15V on SF3000? (RTK base)
Charloz24
Posted 5/5/2023 10:47 (#10216866)
Subject: 15V on SF3000? (RTK base)
near Mtl, QC
Im relocating my RTK base, and decided to put a LifePO4 battery with 2A smart charger on it as power source. (Before I was directly on a 12V power supply, worked good but since the radio did go bad this year, my JD tech advised me to use a deep cycle battery, as it helps stabilizing voltage, less voltage spike )
Well now on the new setup, I see that the battery (or the smart charger) is giving 15V to the SF3000. It is too much or ok?
