Posted 7/24/2009 13:51 (#786626) Subject: How do I take the rotor drive hub apart?(1680)
IL
I want to go thru the rotor drive hub apart to go thru the spring and cams, etc. I believe I need to make a spring compression tool to release pressures, but looking at it this morning, I couldn't find the stud holes to screw the pull bolts into ( I need to look closer again).
Any step by step ideas are appreciated.
