Leesburg, Ohio | Don't have the intructions for a CIH, but you can download the manual at the following website:
http://www.agleader.com/support.php?Page=manuals/ym2000
I did not see any installation intructions on the website or in the manual.
I have a complete YM2000 manual and the installation intructions for a deere combine. I could probably fax the installation intructions if that would help. (about 30 pages) The basics would be the same, but the pics and specifics won't match your machine.
I would suggest you call Agleader 515-232-5363 and see if they still have a copy of the exact intructions for your series of machine.
Here is a list of the general components that must be installed:
elevator speed sensor
ground speed sensor
header height sensor
clean grain elevator chain adjuster*
grain flow sensor
moisture sensor*
cab wall connector plate
monitor unit in cab
(*requires some cutting and metal work) | |
