Boone, Iowa | I bought a kit from NAPA that is an air tool with a wheel on it. The wheel is made out of material that works like an eraser. We have used this to remove decals off of a Case-IH 9390 and works like a charm. Pick up a can of 3M adhesive remover and go over the area, after using the eraser wheel. I would be very careful if you decide to use heat, since it will not take much heat to soften up the stickers. It may be cheaper to have a body shop remove them for you.
Edited by jedeka 7/17/2009 15:01
